Mcleod RXT
Mcleod RXT
after weeks of searching the forums for reviews, i went with the RXT. a few days ago, i had the above mentioned clutch put in my trans am and its the best clutch i have ever ran. in the 12 year history of my car i have ran had 5 other setups and this is by far the smoothest of any. it holds the power and engages beautifully.
Thanks for the kind words and support. I highly recommend using the OEM master with those clutch's due to the fact they only require .400" of bearing travel and the larger bore masters tend to over stroke the pressure plate.
If you have one currently you may want to look into putting a pedal stop at about 7/8" to 15/16" of rod travel. For those that have the OEM and are in the market for both a clutch and the master then I say keep the oem style if your going with the RST/RXT clutches.
Just installed the RXT on a C6ZO6 and so far it is awesome. I am still in the break-in period but it has smoothed out during the engagements and drives like the stocker did with the same engagement point and mannerisms. I used the McLeod flywheel and the stock slave cylinder. I have about 270 miles on it and can't wait to get it broken in. Great clutch.
