New Output Shaft Seal Leaking
Old 05-17-2012, 11:37 PM
Ferocity02's Avatar
Default New Output Shaft Seal Leaking
I just put in a built T56 and the output shaft seal is already leaking. The seal was brand new from Tremec. The seal has a small visible gap between it and the slip yoke. Is this normal? It's almost like the ID of the seal is too large. Is there a seal out there with a smaller ID that will actually seal against the slip yoke?
Old 05-18-2012, 04:51 PM
Ferocity02's Avatar
Bump!
Old 05-18-2012, 08:10 PM
Dave-1970's Avatar
Yeah the seal that comes on the Tremecs go bad real quick. Mine starting leaking too. Check out D&D performance for an upgraded seal. I think the part# is BB80... It has a steel body and is much better than what Tremec slapped in there... http://www.ddperformance.com/
Old 05-18-2012, 09:58 PM
thesource's Avatar
I use a National seal and almost never ever have an issue. Your bushing in the tail housing might need to be replaced as well.
Old 05-19-2012, 02:03 PM
Ferocity02's Avatar
The bushing was replaced.
Old 08-01-2012, 07:27 AM
TOYBOX's Avatar
Can I ask what number is on the national seal? I just got one from GM $42!!
Old 08-01-2012, 08:33 AM
UMD_Jesse's Avatar
Location: Fairfax County, VA (You know you're here when you see the bad roads)
Good news is you dont have to yank the transmission to replace it
Old 08-01-2012, 09:56 AM
calhoon's Avatar
That seal has several sealing lips and an outer stone shield. The gap you see isin that outer stone shield . It should not contact the yoke.
Quick Reply: New Output Shaft Seal Leaking
