LQ9 pilot bearing install?
Does this look correct? I left the bearing my freezer overnight, set it in place and lined up a 15mm socket and tapped it into place. It went very easy. i just want to make sure that this is what it should look like when done.
thanks
thanks
yes that is the wrong pilot bearing... if you install that bearing with a f body t56 you will either damage the transmission or crack the block when you go to tighten the bolts on the bellhousing
