T56 Sealing Ring on Main Shaft
What is the purpose of the sealing ring that's on the end of the main shaft in a T56?
The reason I ask is because on my T56 swap into my Silverado, I have some adjustability in the intermediate driveshaft and can slide the driveshaft forward enough so the slip yoke pushes up against the sealing ring. Right now it's adjusted as far away from the sealing ring as possible. There is only about 1/2" of total adjustability.
