Tranny filling
Tranny filling
Ok so after draining my tranny fluid and not really wanting to go through the hassle of taking the center console apart to get to the shifter and to fill the tranny. So after trying to find something to use under the car to fill the tranny and I came across an idea that worked really well. Using a yard sprayer..that's right, the thing you use to spray the weeds and bugs around your house. Just don't use it again around the yard without cleaning it good. Just fill it up, pump it up and stick the sprayer tube/nozzle into the fill hole on the tranny and let it go. I filled my tranny in no time with minimal effort. Just thought this might help some lazy innovative person like myself that doesn't want to go through the hassle of taking the center console apart.
that works, and a hand pump fluid pump, or midy vac. Or even a long *** tube in the engine bay, will run downhill slowly into the trans fill if you dont let it sag and loop lower the the hole. Ive seen someone with 2 people do that. Down side is when its full you have 6 feet of hose to drain out down by the trans. Or with a hand pump, or yard sprayer is a mess to store till next time your gona use it just for fill the trans again. You can get the cheap fluid pumps form autozone for like $5 use it once then thow it out, not even worth the time to clean out the lines, once then get fuild in them they don't stay on the pump that well too, and come off and you pump fluid all over you
I had my shifter out and did this, worked out well. Just put a funnel in the little hose and pour it right in. And the wipe the funnel out
https://ls1tech.com/forums/manual-tr...nside-car.html
