Where to get Clutch Fluid Reservoir cap?
Okay I've spent several hours trying (online)to find a part# for a clutch fluid reservoir and/or cap for my 99Z28 with no luck. I also went to 2 different autopart stores with still no luck!
Does anyone know the part # for the GM cap, or the GM cap/reservoir combo?
I did find some nice billet aluminum reservoirs(Ring Brothers 99000-4501B and Canton Racing Products 80-400) but I'd rather not spend $92-$140 unless i can't avoid it. Wilwood does have plastic type one (Wilwood 260-7577 $60) but its a remote reservoir for brake system and has a 4oz capacity, not a 1.5oz.
http://factory5roadster.files.wordpr...2/img_6348.jpg
I'd prefer the least expensive route possible.
Anyway I'd appreciate your help and opinions
Thanks
Thanks
Well, I just found out GM doesn't sell the reservoir and cap separate, at least now they don't!
That would explain why I couldn't find a pt# for the cap and/or reservoir anywhere online or at the local auto part stores.
So does anyone/sponsors have a possible solution to my problem?
Here's a kit from Wilwood that contains everything from hose to cap. Shop around, and you can probably find it for $20 or so. The reservoirs are cheap at Jegs or Summit.
A gas cap off a older Briggs and Stratton lawn mower will also work. I tried it by chance to see if it fit when making a homemade clutch power bleeder adapter for my Menards hand pump pressure tank.
Location: Just because the voices aren't real, doesn't mean they're not right!
Maybe keep this one in mind for the future.........
http://store03.prostores.com/servlet...-Clutch/Detail
