Tight budget. Opinions wanted
Old 06-03-2012, 01:46 PM
BKsNHRA's Avatar
Default Tight budget. Opinions wanted
Im on a real tight budget right now. I'm not haveing any trouble driving the car yet but if I hit the go pedal the stock clutch just will not hold up. Car put Down 380 hp and 373 Tq. Is daily driven and will see the track about 4-5 times a year. The most aggressive tires it might see is a set of drag radials. Most of time it's on regular street tires
So the 2 clutches I'm lookin at are a spec stage 1 and a new stock flywheel or a ls7 clutch kit. Car has new hydraulics that were replaced less than 12k miles but the clutch was not. Which clutch would you guys go with for a dd on a tight budget? Other recommendations will be considered.
Old 06-03-2012, 03:15 PM
chrysler kid's Avatar
You can get a diamond stage 2 for about the same price. Jason tends to also have lightly used units he sells at a discount
Old 06-03-2012, 09:15 PM
BKsNHRA's Avatar
I'll definatly keep that in mind.
