T56 Bearing and Shim Kit - Where to buy single parts?
Old 06-03-2012, 05:44 PM
95mysticta's Avatar
Default T56 Bearing and Shim Kit - Where to buy single parts?
I only need an output shaft bearing and sleeve not the whole kit that are avail on thegearbox.org or ddperformance.com. Do these places let you buy single parts from a kit and is there another place i can look that just sells individual parts?
Thanks Alot!
Old 06-03-2012, 05:52 PM
Exidous's Avatar
The bearing you can probably get from RockAuto. Any other individual part I'm certain theGearBox will be able to help you with. They've had fast shipping and great customer service both times I've ordered from them.
Checked rockauto and I see both items for the cheap!
Old 06-03-2012, 06:10 PM
Ferocity02's Avatar
Email the gear box and see if you can get the bearings individually, I'm sure you can.
As for the shim kit, you will probably have to buy the whole kit, not individual shims.
Old 06-03-2012, 09:19 PM
jmd
jmd's Avatar
the last roller bearing on the mainshaft that's non-tapered is an AC Delco item.
Old 06-04-2012, 05:54 PM
95mysticta's Avatar
Thanks guys got an email this morning from the gearbox and its 26 bucks vs the 150 for the whole kit.
Quick Reply: T56 Bearing and Shim Kit - Where to buy single parts?
