Spec P-trim twin disc Daily Driver?
Old 06-04-2012, 11:29 AM
stangs400's Avatar
Default Spec P-trim twin disc Daily Driver?
So I picked up a brand new Spec P-Trim for my turbo lsx. IT is the one with the dual 6 puck disc. Im only going to be pushing around 600rwhp, but wanted something with a lil more wiggle room just in case I decide to turn up the boost. Question is, is this clutch going to be a good daily driver? I want something with basically no clutch chatter, but being that it has the puck style discs, im afraid it will chatter. Did I get the wrong clutch?
Old 06-06-2012, 04:00 PM
Iowa WS-6's Avatar
When i put in my 402 i decided to go with the p-trim since i have had great luck with the previous spec clutches I've owned. the shop that put the engine in also installed the clutch and i have to say i was very disappointed with it. it seemed to have a different engagement point every time i drove the car. i ended up taking it out and going with a different setup.
Old 06-08-2012, 12:11 PM
SNLPerformance's Avatar
How much power do you plan on making when you turn the boost up?
Old 06-08-2012, 03:08 PM
stangs400's Avatar
Ill most likely stay around the 600-700rwhp mark. doubt Ill go higher.
Quick Reply: Spec P-trim twin disc Daily Driver?
