Fastest Six Speed List
Old 02-10-2015, 03:15 PM
  #281
vetteboy2k's Avatar
Originally Posted by blue99fbody
do it, more competition is more motivation to keep pushing the stick and not jumping ship to a boring auto.
I hear ya.
Old 05-06-2015, 09:06 AM
  #282
ATSMATT's Avatar
Time for an update. Since the 9.17 pass I've added a 10 point roll cage and all additional safety equipment. This car is legal under all NHRA rules. After fighting for traction I finally got the IRS suspension hooking decent enough to pull off a few 8 Second passes. If my research proves right this is the new GM 6 speed IRS suspension record.
The transmission is a TR6060 from the CTS-V modified and built by RPM Transmission.
Aluminum 5.3L LC9 block stock bore
stock crank
25 psi on E98 fuel
full exhaust
All glass, power windows
Complete interior
OEM steering column
Motec M150 ecu
8.78 @ 166.79 - 1.44 - Mcleod st twin ----- 325 --- Twin 6266 ------------ 3150 ATSMATT
Video
Old 05-06-2015, 09:09 AM
  #283
thirdgenbum's Avatar
wow! congrats man!
Old 05-06-2015, 09:10 AM
  #284
SNLPerformance's Avatar
stock crank
25 psi on E98 fuel
full exhaust
Complete interior
OEM steering column
Motec M150 ecu
Video
Dedicated Motorsports Is300 goes 8.78 @ 166 mph setting the new GM 6 speed IRS suspension record - YouTube
Congrats!!!!!!!
That is getting it done!
Old 05-06-2015, 09:51 AM
  #285
SSSTANG#1's Avatar
Is the TR6060 synchronized?
Old 05-06-2015, 10:16 AM
  #286
ATSMATT's Avatar
I did a couple 9.0's with a synchronized tr6060. Now 1st-4th has been faceplated.
Matt
Old 05-06-2015, 10:59 AM
  #287
blue99fbody's Avatar
nice pass I guess I need to get my *** in gear on getting mine back together.
what was the time/mph to the 8th?
Old 05-06-2015, 11:14 AM
  #288
ATSMATT's Avatar
I meant to post the time slip actually. I'm curious what your car does in the 1/8. I've made probably 15-20 passes with this setup and can never get the power down on the short track. I've pulled a bunch of torque out down low.
Old 05-06-2015, 02:24 PM
  #289
not to bad 60' is where your lacking. ive been 5.56@130 in the 1/8. mph is there have you had it on a chassis dyno?
Old 05-06-2015, 04:19 PM
  #290
ATSMATT's Avatar
The IRS presents a huge hurdle when it comes to laying down a good 60 ft. The Supras do really well but the IS300 has some quick ratios for camber and toe. All the racing I do doesn't allow the movement of any suspension mounting locations so I'm stuck with what I have. Its a work in progress for sure.
I've dynoed it a couple times laying down 1130-1160hp @ 25 psi. I have the torque dialed back to about 930 lb ft.
Matt
Old 05-27-2015, 08:48 AM
  #291
1999Black_Z28's Avatar
10.54 @ 134.69 - 1.56 - Mcleod RXT ------- 347 --- Comp 7479-------------- 3720 – 1999Black_Z28
Car 939
Old 05-27-2015, 11:16 AM
  #292
Jeremy@RPMTransmissions's Avatar
Thanks! Got you added to the list. Great pass!
Old 05-27-2015, 11:18 AM
  #293
Just wanted to let everyone know. I am doing some house cleaning on the list. I have removed users from the list that have not been active on the board in over 2 years. I hope this doesn't upset anyone. But if they haven't logged in to LS1Tech in that long I can only assume that they have moved on to another platform.
Old 05-27-2015, 08:24 PM
  #294
Zmg00camaross's Avatar
Come this fall I am moving up that list
Old 09-13-2015, 06:47 PM
  #295
Ray is putting a hurting on that record this weekend!
Old 09-14-2015, 10:45 AM
  #296
8.33 @ 168.5 - 1.32 - Monster 8.5" triple ------ 376 --- LSX Realstreet 76mm - 3175 - Blue99fbody
Old 09-14-2015, 11:25 AM
  #297
Congrats again brother!!!!
Old 09-14-2015, 11:26 AM
  #298
Jeremy what's the likeliness of us leaving his old setup numbers up there to show guys Monsters are getting it done?
Old 09-14-2015, 12:08 PM
  #299
Agreed my one eye monster does work
Old 09-14-2015, 04:08 PM
  #300
Edited it with the previous combo for you.
Quick Reply: Fastest Six Speed List
