T-56 Whining - Page 2 - LS1TECH
T-56 Whining
Thread Tools Search this Thread
Old 07-19-2012, 11:29 AM   #21
wrd1972's Avatar
My T56 had some light whine and the rocks in a shoebox sound prior to rebuild. I found the mainshaft bearing preload was a little on the loose side. After tightening it up to tremac spec, it was much quieter.
wrd1972 is offline   Reply With Quote
Old 03-02-2017, 09:30 PM   #22
SSSTANG#1's Avatar
I discovered this thread after doing a search for information on T56 noises. Mine is a magnum that had a 4th gear whine from the day I installed it (new). I recently sent 1-4 gears to Liberty's to be faceplated. When I got the gears back I put everything together and now have about 500 miles and a few 1/4 mile passes on it. Right after I got it back in I noticed a slight vibration noise at idle that got more noticeable as it warmed up. At first I thought it was header tubes vibrating or something lose. Now that noise has become a lot louder and today it actually concerned me.
Another thing is, even though it is faceplated, 4th gear grinds and is not easy to engage. I plan to call Brad at Liberty's tomorrow but thought I'd see if anybody here has any ideas. I'll probably pull it apart next week and check it out.
SSSTANG#1 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Loud whine, 1st gear decel? WS6wanted Manual Transmission 2 11-05-2016 12:21 PM
Whining noise with clutch out. VandykeT/A Manual Transmission 5 12-02-2015 09:12 PM
Transmission Pump Damaged? RCKTGRL Automatic Transmission 5 05-21-2014 07:21 PM
T56 Noise Reckless95z Manual Transmission 0 06-19-2013 10:25 PM
v8 swapped t56 rx7 whining from trans????? thefastlife Manual Transmission 20 05-06-2012 11:14 PM
Tags
2002, 2012, accel, camaro, m12, make, making, noise, noisy, nosie, problems, ss, t56, transmission, whine, whining, whinning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
