Clutch won't disengage, possible pressure plate issue? - LS1TECH
Thread Tools Search this Thread
Old 08-06-2012, 12:48 PM   #1
BlueB4C's Avatar
Default Clutch won't disengage, possible pressure plate issue?
Ok, so over the weekend I installed an old used clutch into my 99 that I had laying around from my 02 Camaro that looked to be in fine shape so I kept it. I also installed a brand new master and slave but now the clutch won't disengage. My friend and I bled the slave manually a bunch (whole bottle worth of clutch fluid worth) and also used a mightyvac 2 times, only getting tiny tiny bubbles once in a long while while doing that. Question is:
Could this be a pressure plate issue of some sort, all the stock bolts were re-used, I know the stock clutch is self adjusting and all so I figured if anything would go together no shims needed it would be stock parts. The reason I ask about the pressure plate is I removed the clutch from my 02 because I heard a bang one day while driving it and the clutch wouldn't disengage anymore. I upgraded the clutch in that car because I assumed it was a hydraulic issue when I replaced the slave and master in that car. Just seems like an awful big coincidence that this car is doing the same thing with the same clutch in it. So what does everyone think?
BlueB4C is offline   Reply With Quote
Old 08-06-2012, 01:45 PM   #2
Scoobysnacks's Avatar
What type of clutch is it? Ls7? If so, from what i have seen on here is even with the new hyraulics, the pressure plate is self adjusting and it adjusted to the orignal hydraulics that were in when it was installed. You may need a new pp.. but dont quote me on that...
Scoobysnacks is offline   Reply With Quote
Old 08-06-2012, 03:52 PM   #3
BlueB4C's Avatar
It's a stock 2002 Camaro clutch so It's an LS6. The more I think about it the more I believe it's the pressure plate, it must just be adjusted all the way in like you say and I suppose that could have accounted for the pop I heard in the 02 car when I removed this clutch originally. Well does anyone have a spare good pressure plate? haha
Old 08-06-2012, 04:24 PM   #4
sepsis's Avatar
When I heard a "pop" and the clutch stopped functioning in my old Mustang, the springs in the pressure plate took a ****.
sepsis is offline   Reply With Quote
Old 08-06-2012, 04:30 PM   #5
BlueB4C's Avatar
Damn, see all the springs "appeared" ok to me, it's the only reason I saved the thing, serves me right for trying to be cheap with this build.
Old 08-07-2012, 03:52 PM   #6
LS1Tech Sponsor
SNLPerformance's Avatar
Sounds like it is in fact the pressure plate issue. If you do look into buying a clutch, our Level 1 or Level 2 would suite your needs just fine. We offer complete kits. Give us a call @ 817-750-2000, and we will get you taken care of. I'd hate to see you have to replace the clutch again.
SNLPerformance is offline   Reply With Quote
Old 08-07-2012, 06:04 PM   #7
BlueB4C's Avatar
Quote:
Thanks for the info, I ordered an LS7 kit today however, I would love a Monster in the future though when I get enough saved to make this car fast but for right now money was too tight and this car is too underpowered to warrant one but it does suck having to pull this trans back out either way.
Related Topics
Thread Thread Starter Forum Replies Last Post
T56 help clutch not disengaging bradw18 Manual Transmission 1 05-23-2015 04:39 PM
99 z28 monster clutch release issues...Need Help ShiftyDGAF Chevrolet Camaro 1967-2002 1 11-18-2014 05:13 PM
Clutch issue I need some help please jamier2 Conversions & Hybrids 2 11-21-2013 09:42 PM
New clutch install, now car won't go into gear, PLEASE HELP!!!! Turbo T/A Manual Transmission 15 09-17-2013 12:37 PM
The Clutch Prob Post jaberwaki Manual Transmission 32 07-16-2012 05:58 PM
Tags
1966, 96z28, add, car, clutch, cutch, disengage, ford, installed, mustang, plate, pressure, replaced, tranmission, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
