Bleeding a Tick Master Properly
Old 05-17-2015, 05:09 PM
  #41
ChevyDriver's Avatar
Im having some issues with my tick master. The first 3/4 inch of pedal is completely dead. nothing there. i have had to bring my clutch pedal an inch or so above the brake pedal because i was having disengagement issues. It also feels like after long drives the engagement point gets closer and closer to the fire wall. Or maybe im just going crazy.
My friend has the exact same setup as me ( master, slave, clutch, etc.) and i got to sit in it and try it this weekend. its rock hard, a nice short throw and there is no play at all. Mine feels like **** compared to his but if i didnt have his to compare with i would say mine doesn't feel bad at all.
Will this method help me? is there air in my system or is it something more serious?
Old 05-18-2015, 08:56 AM
  #42
thirdgenbum's Avatar
it sounds like tell tale air man. Especially after things get warm. air in the system means it will hold heat and boil more easily. use this method. it WORKS.
Old 05-18-2015, 04:03 PM
  #43
well i gave this a go for about 2 hours today but seen no improvement. it seemed i was only making things worse. So i decided to pull the master out and inspect it. it sounded like it was letting in air somewhere and sure enough it was. About 700miles on it so im just assuming i got a dud one, no biggy. I set it on the bench and started pumping it and could see and hear tiny little air bubbles forming in the masters little cup thing.
Old 06-27-2015, 09:06 AM
  #44
BlackNHRA's Avatar
So I am not sure if this is related but I have looked and looked. I have bled numerous times and even had some of the local gurus come around and tinker. Used the Mityvac method and bled as such. All the bleeding I have done still leaves me still getting a very partial engagement on the clutch. For example going into first gear it grabs the clutch ever so slightly and tries to roll the car. Would that be the total distance of the slave as an issue like a shim? or would that be the slave not being pushed far enough? Would air cause the slave not to press hard or far enough?
Old 05-29-2019, 12:37 AM
  #45
Azriel_Strife's Avatar
Hey all, having the same issue as above.
I've tried this bleeding method and my clutch still doesn't disengage fully, issue actually seems worse than before, still have a half inch of spongy pedal and it makes a slight squirting noise when you cycle the spongy part. I'm out of ideas, ready to give up and sell the car honestly.
Thought this tick master was going to be the bees knees, but so far it's taken about 7 hours of my life and i can't drive my z06 anymore.
Old 07-25-2020, 09:30 PM
  #46
Fgalleno1's Avatar
Default Bleed that inch of moosh
Originally Posted by dr_whigham
True, true, and TRUE!!
I can't stress enough how important it really is to strictly bleed that inch of "moosh" you get. It makes a WORLD of difference.
how do u bleed that inch of moosh?
Old 05-02-2023, 07:54 PM
  #47
CTC B4Z's Avatar
Literally bumping this up cause I'm pretty pissed right now, that once again this procedure is rediculous. The master was never drained, I had un hooked it from the slave, it sat for a month while I rebuilt the trans, reconnected and several attempts to bleed and nothing but good bubble free fluid and zero from the pedal.
The. ****.
Old 05-03-2023, 10:50 PM
  #48
wannafbody's Avatar
Not sure if this will work or not but it's worth a shot. Jack the back of the car high in the air. Loosen the cap on the reservoir and pump the pedal 35 times or so. You might be able to burp out your bubble.
Quick Reply: Bleeding a Tick Master Properly
