rattle clutch in idle
Both in gear and in neutral. Been having the problem of a spinning grinding noise clutch in while moving and giving throttle. Sometimes will rattle clutch engaged at idle and will go away clutch disengaged a sure sign of a bad throwout bearing. However now the horrible rattle at idle clutch disengaged. The more throttle I give the worse it is. Also the problem is not there until the car is warmed up. When cold there's no rattle or grinding.
