Light Clutch Options
I decided to pull my trans this winter and send it out to get refreshed. Since the trans will be "new" I want to get rid of my Spec Stage 3 and stock flywheel and get something lighter. The stock bellhousing will also get replaced.
I have been thinking about a 5.5" or 7.5" Tilton, but I don't know what my options are since it doesn't seem to be a popular option. What are some other options for a really light setup. I don't care if its not really friendly, I don't DD my car and my car is going to be around 3100 with me in it by spring time.
Now on another note I'm planning on doing an LS swap in a couple years and I know that I can swap the input shaft and front cover and use an LS style clutch setup on my LT1. Would it be worth while do just do the LS clutch setup now since I will be buying a different bellhousing and everything else?
Any info is appreciated
I have been thinking about a 5.5" Tilton, but I don't know what my options are since it doesn't seem to be a popular option. What are some other options for a really light setup. I don't care if its not really friendly, I don't DD my car and my car is going to be around 3100 with me in it by spring time.
My original idea was to get a Mcleod Street twin for an LS motor and swap it into my car, but those are heavy as hell.
Not sure on the other options.
My car is built for similar duty as yours, though I do a few passes a year as well.
We usually do a couple trips to the track every year too. My car hasn't made it yet since either my winter mods aren't done or I have to work haha. Hopefully next summer is a different story
I'll look into the aluminum flywheel for the street twin, but I would still like a lighter option than that.
Anyone on here running a 5.5 or 7.25" twin or triple disk clutch?
I'm honestly thinking about just ordering one and seeing how they feel. Right now I have a stock flywheel and a Spec Stage 3. So I'd basically be going from one of the heavier options to one of the lighter options. Then I can see if I can tolerate it or move on to something in the middle.
So what has to be done to get one of these 5.5" Tilton clutches to work. Can I make it happen with y trans setup for an LT1 or would I be better off switching to an LS input and front cover? What do I use for a slave?
You don't want a slipper clutch...but I understand the desire for something lighter. We offer a 7.25" mini-twin that is rated to 800lb.ft at the crank and it really isn't too bad to drive either. Keep in mind that lower inertia setups require more RPM when leaving from a stopped position though. Our kits are fully rebuildable too. I have provided a link below (for the LS based mini-twin). Take a look and let me know if youn have any further questions. Thanks!!
http://www.specclutch.com/cars/Chevy...2000/Mini_Twin
I run a 5.5 tilton......it's a badass! Only cost me $400 bucks to make new again to. I did the custom install myself. It takes a little effort but it's worth it. A buddy has a spec 7.25 and my tilton is much smoother. It also takes a little tuning. Where you at op?
I dd this clutch.
I dd this clutch.
Sorry a little off topic.
HioSSilver, I have to ask, what the hell does your car weigh to go 131 in the trap with only 417rwhp? Nice job. You must have been getting hard launches too. Hell I only went 129 with 510rwhp@3800lbs.
There is a local guy with strip out Firehawk that has gone 11.0@126mph with 410rwhp and I think his is down too about 2800lb car weight. Not sure on his race weight. Likely around 2950, possibly less.
If you have yours that light, it might make a grabby clutch easier to drive. I do not think I would try the Tilton on my set up, but your results are intriguing.
Sorry OP.
Sorry OP.
Sorry OP.
Sorry OP.
i will tell you this.....op is on the right track if he wants his car to accelerate. Rotating weight makes much more difference than dead weight does.
If you look at what your car makes power wise and runs time wise you can see the correlation between our cars and the different ways to get to similar #'s.
No problem on the off topic, I like getting a little more info anywhere I can
My car is going to be GUTTED haha, no sound deadening, no cruise or AC, no rear seats, yadda yadda yadda. I'm shooting for under 2900 with sway bars and 17x11s.
I was considering going with a heavier clutch setup like 22.5#s or so, but I really want to do a button style setup and see how it is.
HioSSilver-what has to be done to fit the 5.5" Tilton? I was considering going to a LS1 style trans, but I just got a new driveshaft and don't feel like messing around with a bunch of extra stuff. And do you have any vids of how your car drives with the button clutch?
Can I use my slave and fork setup and get a different bearing to run the button clutch? What flexplate should I get? As light as possible thats SFI approved or stock?
I emailed TDP and their clutch options are the same weight as stock. I really want to try a lightweight setup so I'm just going to start gathering parts and do it. I'll probably get a 5.5" twin with organic disks. I need to figure out flexplate & hydraulic options. Can I use the stock hydraulics and fork with a different throwout bearing?
I have been searching and searching, but I don't really come up with anything and when I do it's usually old *** threads
Turnin, if you wanted to maintain use of a single-disc you could opt for one of our Aluminum Pressure-Plate Stage 4 setups with a 3 or 4-puck disc and an aluminum flywheel. This offers a significant savings over the stock setup and the plate and flywheel would be rebuildable for future use. I don't think you will find a lighter single-disc option anywhere.
cut up the stock bell to get everything setup.
triple clutches for some time now. I have your Stage 3 clutch and like it, but
I just want to try something different. My car is getting lighter and I'm
starting to get into autox & road racing so it seems like a decent option going
to a really light setup.
