Monster 3 clutch pics
Yeah, I saw that. I'm trying to learn as much as I can from this forum. Were you hot lapping? I would think that maybe the lighter steel got too hot, thus causing the premature wear on the pucks.
I'be no doubt they will go above and beyond to help figure out what happened.
On an aside, that flywheel is quite spectacular. Seriously, would you be interested in getting rid of it?
Looks like you over heated it to me. No pun intended, but these are NOT drag racing clutches. Beat the snot out of them, and they are going to overheat and fail. My guess is too many high RPM clutch drops.
What would you want with it?
Yes it was broken in correctly, 500 miles of stop and go s
Not all in the same day, no beating on it.
Snl always had good customer service, the clutch has to be out of the year warranty, due to the car is never driven only on nice weekends
Measure the clutch puck thickness?
My guess it was wore pretty thin and then the pressure plate couldn't clamp it and it slipped.
Happened to mine - after about 4k miles and 500+ track passes. It just wouldn't grab on a launch.
I didn't let mine get at hot as yours
Put a 11" race disc or a level 5 in it and let it rip
OP,
Shoot me an email at Steve@monsterclutches.com and Ill go over all of this with you. From the looks of it, it looks like it started slipping and once it starts it will self destruct. That needs to be caught immediately. This is what happens if it is not caught
