High clutch pedal?
High clutch pedal?
Just replaced the clutch in a friends 2000 T/A. It had a spec stage 1 in it, replaced with stage 2. It already had a tick master cylinder, i put a new slave cylinder and tick remote bleeder in it. The clutch engages fine, but the pedal is really high where it engages. I could adjust the master, but it just moves the location of the pedal, doesnt change the fact that the engagement is at the top of the travel. We did not use the spacer behind the slave, that would only make things worse.
The pedal was high before we replaced the clutch, so it isnt anything caused by the install.
Any ideas?
Thanks
Any ideas?
Thanks
Ok, thanks. I have a spec 3 in my lt1 and it feels completely different. I just wanted to make sure I wasnt missing something.
