clutch not disengaging all the way
Old 08-16-2013, 02:26 PM
camarols2ss's Avatar
Default clutch not disengaging all the way
i drove my car to get breakfast and i come out of the store and my clutch is on the floor, so i replaced the slave cylinder and clutch master cylinder and now it doesnt disengage the clutch all the way, can anyone help me, wat can the possible causes be, ots a 2002 ss t56 6 speed thanks
Old 08-16-2013, 03:40 PM
BALLSS's Avatar
sounds like you don't have all the air out of the hydraulics. bleed some more
Old 08-19-2013, 06:47 AM
the clutch grabs really high and doesnt fully realease the clutch n it slips if u give i give it gas would this still be a bleeding issue??
Old 08-19-2013, 09:08 AM
SPEC-01's Avatar
You seem to note two different things here. One is a lack of full release and the other is a higher pedal and slippage. These characteristics are conflicting unless you are pushing through the clutch (over-extending it when the pedal is depressed). What clutch kit do you have? Does it use a shim? What Master and Slave are you using? Is the Master Adjustable?
Old 08-19-2013, 02:38 PM
the clutch is a spec stage 3+, i had a shim on it which i removed n the problem seems to have gone away, clutch grabs about half way up n all gears are functional, thanks for your help, hopefully it continues to work properly
Quick Reply: clutch not disengaging all the way
