Mgw shifter install help....
I would like to ask how hard is the installation of this short shifter kit for f body t56 camaro... Is it straight forward install or it needs some modification... Any advice would be highly appreciated specially for those who have this kit on their car... BTW my kit comes with oem size shaft... Thank you!!!!
the only problem you might have is getting the old shifter unstuck from trans housing because of sealant. I took a pair of channelocks and gently pried against the passenger side of the shifter housing using the hole in floor as leverage . there is a lip on the existing shifter to grab. you will see the outline of the sealant used ,clean and follow same pattern and don't get sealant in the bolt holes or you will hydraulic and blow out the housing holes . you PM'd me at one time but I couldn't get the connect back to you. the oldman....
Thank you very much old man!!! your advise in removing the plate really helped me a lot specially in my case that still have the original shifter... i got it installed now, very happy the way the car shifts right now comparing to my stock ones its like day and night... The only thing is the noise coming from the shifter area im not sure if its vibration or just road noise is this normal on this shifter kit? did you have this noise on your car? just wondering... they say its common to have noise on this aftermarket shifter...
Cheers!!!
Cheers!!!
I see.. thanks REDBIRD... Over all im very happy with this shifter upgrade its worth the time and money... I enjoy driving my car more... MGW Rocks!!!!!
hey vette not related to vibration, got side tracked. ramair, thanks for info on boot. I always like to have a spare on the odd things. now if we could just get a good console door repop that doesn't cost an arm and a leg. vette vibration could be several things one of the easiest things to check is the tailshaft bushing , but that entails pulling the drive shaft and checking your trans yoke for grooves or rubs indicating wear of bushing in trans. I stand corrected check u-joints for wear first. grey moment struck again..the oldman....
Cheers!!!
Cheers!!!
I just installed one on my 02 Camaro as well. I noticed a little more noise but nothing too major. Glad to hear you like the shifter though. I love mine, so much better than stock
