Help Needed Transmission Removal
So, I've a '99 TA that needs a new clutch slave cylinder. The car is basically stock aside from exhaust and brakes. I've researched the procedure online and watched quite a few demonstrations on YouTube. I'm to the point where everything's disconnected and I've removed the 8 bolts that held the transmission to the bell housing. From what I've learned, the transmission should be able to be pulled free of the bell housing, allowing me access to the slave cylinder. Well, that is not the case. This thing will not budge. I've checked and rechecked my work and cannot seem to figure out what I'm doing wrong. Am I on the right path or do I need to change course a bit? Any help would be greatly appreciated. Thank You.
You said all 8 bolts, including the one on top of the passanger side? I had to put a screw driver in a pry each side, I belive there's 2 dowels that line it up, they get stuck all the time
Yeap. Drive shaft, tortion bar, all the bolts, wires, and the slave cylinder line have all been removed and disconnected. I appreciate the advice and will try spraying down good with PB Blaster, letting it soak, and prying on it. Hopefully I can break 'er loose! It amazed me that the transmission shop that replaced the clutch wouldn't have replaced the slave whilst having it apart, since it is a rather inexpensive part. This little deal, combined with another experience with that outfit... I won't be going back!
Did you remove the shifter? Feel all around the transmission to make sure there is no where for it to be stopped when pulling back.
Yeah also make sure the trans crossmember mount is taken off.
Thank You All for the advice! Some PB Blaster, a sharp chisel, and a hammer and I had it separated from the bell housing and out from under the car in about 30 minutes. I know that's quite a bit of time, but I'm working without a trans jack. Two well positioned ratchet straps work quite well for hoisting the trans back up into position too.
One last question... Would it make things easier to have the transmission in gear when reattaching it to the bell housing? I nearly got it back together, but it won't move that last 3/4 of an inch to get flush up against the bell housing. I suspect the splines aren't lining up and was thinking it would be easier to get things lined up if it were in gear.
Make for damn sure that the clutch disc is lined up correctly.
When I tried to install mine, it wasn't lined up correctly and no amount of coaxing would convince it to go in that last 3/4". But when I loosened everything again and was more careful lining up the clutch disc, it slid right in.
