Re-use ARP flywheel bolts?
Old 09-07-2013, 10:34 AM
badazz81z28's Avatar
Default Re-use ARP flywheel bolts?
Is it a bad idea to re-use flywheel bolts? I have ARP bolts, but I don't know if heat cycles, stress removing them etc etc..make them not "smart" to re-use.
Old 09-07-2013, 10:36 AM
Zmg00camaross's Avatar
I would reuse them no problem
Old 09-07-2013, 11:46 AM
manzo81maro's Avatar
I think that's what the ARP's are designed for...stronger bolt and re-usable because they're not TTY like the stockers...obviously, just re-apply red loc-tite to threads, and I used ARP assembly lube under the head of the bolt before torquing to 85 ft-lbs...if you use the lube, be sure to wipe away any excess after final torquing, because centrifugal force might throw it onto the clutch disc
Old 09-08-2013, 01:29 PM
Rog-
Old 09-09-2013, 07:04 PM
Blackpanther99's Avatar
Either way you will be fine. Go ARP though.
Old 09-10-2013, 08:59 AM
It's not mine! woo hoo!
demonspeed's Avatar
...they're not TTY like the stockers
Stock aren't TTY, either. I reused my factory PP and FW bolts when I did the clutch in my 2000; I plan on reusing the factory bolts when I do the clutch in my 2002 over the winter.
My opinion: get the ARP if you need new bolts or aren't on a budget.
Quick Reply: Re-use ARP flywheel bolts?
