T56 Rebuild-Need Opinion/Help
Old 09-13-2013, 02:16 PM
1slowbusa's Avatar
Default T56 Rebuild-Need Opinion/Help
Hi All,
I am rebuilding a T56 and the 1st and 2nd shift fork is broke. See photo. What do you guys recommend I do? Put a new 1st and 2nd gear shift for with all new pads in and and call it good? If not, what parts do you recommend I replace. All the gears look good.
Also, the 1st and 2nd gear slid off of the shaft without using a pulley. Is this normal, any future issues with this when i put it back together?
Thanks in advance for the input.
Attached Thumbnails T56 Rebuild-Need Opinion/Help-1.jpg   T56 Rebuild-Need Opinion/Help-2.jpg   T56 Rebuild-Need Opinion/Help-3.jpg   T56 Rebuild-Need Opinion/Help-4.jpg
Old 09-13-2013, 04:29 PM
07kyeringt's Avatar
Yeah that would basically be it if you are just looking to repair. But while you are in there I would replace other things as well. like synchros and such. Look at a Tick performance rebuild kit and redo whole thing. Or is there a budget?
Old 09-13-2013, 04:55 PM
td1168's Avatar
I would definitely do the level 2 upgrade while you have it apart. Make sure the engagement teeth on all your gears aren't rounded and that the synchro ring engagement teeth look good. Your gears ride on needle bearings. They should just slide right off. The online service manuals available are your best friend. They detail the inspection process to make sure you don't miss anything that needs replaced.
Old 09-13-2013, 05:13 PM
07kyeringt's Avatar
Well said.
Old 09-13-2013, 05:50 PM
2 Stroke Racer's Avatar
Send it to RPM and bang gears without worry!
Old 09-13-2013, 07:11 PM
1slowbusa's Avatar
who is rpm and where are they located?
Old 09-14-2013, 12:16 AM
jmd
jmd's Avatar
The 5-6 cluster sliding off may not seem like an issue if you haven't noticed a vibration from it yet. But eventually it shoves the reverse synchro through it's lockring and causes more damage.
https://ls1tech.com/forums/lt1-lt4-m...vibration.html
Old 09-14-2013, 07:05 AM
oldmano2z's Avatar
i had my 1-2 shift fork cryo'ed while it was apart since they don't make a steel one such as 3-4 .
Old 09-14-2013, 10:22 AM
They have my T-56 right now freshening it up.
I've been racing it for years with no problems!
http://m.rpmtransmissions.com/
Quick Reply: T56 Rebuild-Need Opinion/Help
