3-4 shift wont engage under high rpm...particularly after being warm
Old 09-23-2013, 10:54 PM
NW Iowa WS6's Avatar
Default 3-4 shift wont engage under high rpm...particularly after being warm
Car has stock 57k mile t56, spec 3+, Tick master, new GM slave, normal driving and moderate throttle all gears shift great. Full throttle at the track 1-2 and 2-3 are smooth and never miss. 3-4 on my first pass or after sitting a long time is OK, a hot lap or not sitting long I miss the gear everytime even shifting SLOW feels like it engages but just revs up and nothing there. Trans rebuild time?
Old 09-24-2013, 09:17 AM
SPEC-01's Avatar
Does the issue ever affect other gears? If not, this is most likely relative to an internal transmission issue. If it does affect others gears then I have a few other questions.
Does the pedal effort change? How about pedal return? Let me know so I can better assist you. Thanks!
Old 09-24-2013, 09:34 AM
Only the 3-4 shift is bad, pedal is very consistent with this 3+ and Tick master, never gets soft or spongy and grabs like an animal even in stop and go traffic
Old 09-24-2013, 02:28 PM
SPEC-01's Avatar
Based on the description I would start looking for internal transmission issues.
Quick Reply: 3-4 shift wont engage under high rpm...particularly after being warm
