Installing LS7 clutch on an LS1. Do I need the LS7 master slave?
Old 09-30-2013, 06:46 PM
PapeSS's Avatar
Default Installing LS7 clutch on an LS1. Do I need the LS7 master slave?
So iv got a 2000 camaro SS. Putting an LS7 clutch, flywheel. And I'm wondering, do I have to put an LS7 master slave? Or will the LS1 master slave do just fine?
Old 09-30-2013, 07:45 PM
trans_am7935's Avatar
LS1 style hydraulics will work just fine with this setup, although i would suggest replacing the slave cylinder and getting a speed bleeder from Tick. it really helped out with the bleeding process. I did not do the drill mod on my master and mine works great.
Old 09-30-2013, 08:04 PM
Blownbayou's Avatar
Futral had to make my stock master adjustable for mine to work right.... Different with every car
Old 09-30-2013, 09:28 PM
Fair assessment, but of all the clutches to put on your car, this is by far one of the best fitting ones. i would also recommend an adjustable Master Cylinder like Blownbayou did if you can afford it. i went with a Ram adjustable one when my stock one went out, even though i didnt need it.
Old 10-01-2013, 06:35 AM
Atrus_SS's Avatar
Agreed - I used a new Autozone slave (made sure I got the "AP" one) and CMC. Also VERY thankful I bought the speedbleeder.
I did drill mod mine. Been running great, I really like the clutch on my otherwise stock SS. Mine seems to work just fine (knock on wood) with no shims.
Quick Reply: Installing LS7 clutch on an LS1. Do I need the LS7 master slave?
