GTO T56 Slip Yolk Coupler onto F-body T56?
Gents,
I'm looking to incorporate a flex disc in my driveline to minimize shock loads on my diff / axles. I have an F-body T56 and came across the splined slip-yolk adapter a'la the LS2 GTO's.
Does anyone know if this will fit the F-body T56 output shaft, or is more extensive modification required?
Thanks,
Chuck
Thanks,
Chuck
Thanks,
Chuck
Thanks,
Chuck
I'm also doing an E36 swap. My T56 is from a GTO and I have the slip yoke pictured above, but without the rubber disc. Trying to make a plan for how to properly transition to the driveshaft.
Tipsy
I guess a simple 27 spline Yoke http://www.ebay.com/itm/NEW-DRIVESHAFT-SLIP-YOKE-27-SPLINE-3R-GM-MUNCIE-GM-T-56-BORG-WARNER-T-4-GM-T-5-/290300887571?pt=Motors_Car_Truck_Parts_Accessories&hash=item4397480213&vxp=mtr should be all I need.
Tipsy
