Slip Yoke Stuck
Old 10-14-2013, 07:06 AM
moehorsepower's Avatar
Default Slip Yoke Stuck
Well I finally got around to pulling the drive shaft after grenading the u-joint at the shoot out. I tried pulling the shaft out with no luck, then I tried prying out of the trans, same, Then I got a 5lb hammer with a bar and started smacking the $hit out of it, same, wont budge. I'm guessing the yoke splines are twisted, question is, How in the heck do I get it out, especially doing it on your back.
Old 10-17-2013, 07:57 PM
Pocket's Avatar
Put some tension on it first, then whack it. Ratchet straps work great
Old 10-17-2013, 09:02 PM
Zmg00camaross's Avatar
PST shaft? Splines are twisted. Just have to pull, pry and beat. If not a cut off wheel and cut the yoke. Had to do that on a pulling truck lol.
Old 10-18-2013, 02:38 PM
Good idea, I thought of a come along but dont have one, But I do have ratchet straps
Quick Reply: Slip Yoke Stuck
