What clutch should I get
Old 10-14-2013, 10:01 PM
Transmarrowbird94's Avatar
Default What clutch should I get
I am going to be buying heads and a cam and eventually nos I was wondering should I get the gm ls7 clutch or a center force I refuse to buy spec or atc have had bad experiences with both on other vehicles
Old 10-15-2013, 12:01 AM
Philbo Baggins's Avatar
The LS7 is only rated up to 525HP with occasional but not frequent racing. Sounds like your car is easily gonna pass that on spray. I know a guy who had a H/C car with a Monster clutch, maybe the way to go if you're against Spec. I've heard Centerforce is good but no personal experience. If drivability is not a concern get the most aggressive one you can afford. You'll probably want something rated to handle like 600HP with Heads+cam+spray
Old 10-15-2013, 10:43 AM
SNLPerformance's Avatar
The LS7 wouldn't be what I'd recommend if you're going to be spraying the car, I'd personally go with a 28lb Monster Level 3...though I may be a little biased
Don't hesitate if you have questions, Chris 817-750-2000
Quick Reply: What clutch should I get
