Bellhousing ls3-t5wc what works?
Old 10-17-2013, 08:02 PM
Cylinder shaker's Avatar
Default Bellhousing ls3-t5wc what works?
I have an 11" Spec clutch and need to go from the LS3 to my new G-forceT5 trans. Looking at this but no info for what size clutch?
http://www.jegs.com/i/Lakewood/620/15020/10002/-1
Open to suggestions so far cheapest that I have found? Thanks!!
Old 10-17-2013, 09:58 PM
http://ampperformance.com/i-9569621-...llhousing.html
Old 10-18-2013, 08:46 AM
Well, talked to Lakewood quick time. Nothing will work, off to custom land...
Old 10-18-2013, 08:05 PM
S10xGN's Avatar
Huh? They told you that? There are plenty of options from the ones above to some stock castings. Look in the hybrids section, there are a few pertinent threads...
Old 10-18-2013, 08:15 PM
I think we found a work around. I will have a look though, thanks!
Old 10-18-2013, 08:57 PM
badazz81z28's Avatar
If it has the same bolt pattern as T-10 or a TKO, Mcleod and Quick-time both have a bell housing.
May I ask...Why T5? Is that what your car originally had? A TKO or T-56 would be a much better trans and cost less $$
Old 10-18-2013, 10:22 PM
Its going into a C2 Corvette, I had a Keisler TK0 600 shifted like poop notchy, hard to get into gear and it leaked at the speedo cable. I talked to Shaffi Keisler and said that he agreed with me on these issues, but would sell me the latest and greatest model, but not available for months. The T56 would of required major surgery for this to work (and speedo sent out), so I was left with the T5 that I had beefed up at g-force. It was a lot cheaper and will hold up to the 430 hp and torque that my crate LS3 will put out (plus it will shift like an old Muncie).
The bolt pattern is much different for a WC Chevy T5 remember they sit at that 17 degree angle (I believe the Mustang version sits straight as where I got confused at first). Feel free to post up a link if you find something.
Old 10-19-2013, 03:32 PM
jmd
jmd's Avatar
The RM-6037 you linked lacks the 17deg. trans. pattern.
First, look into the RM-6018; they say it's pattern is 23 degrees, but someone may have made a typo that has proliferated over the years of catalogs.
Lakewood makes a dual-trans-bolt-pattern scatternshield for 84-92 F-bodies. It's not new. It accepts the external slave cylinder used in those. There are different slave bore options IIRC for the 93-97 F, and the Cavalier. If you're going hydraulic, that would be a simple way to go.
They also make one for 82-83 F-bodies. Again, dual straight-up and 17deg angled muncie patterns. It has mechanical fork provisions at an angle that suit the 78-up A/G intermediates and 82-83 F. So that may not exactly suit yours, but welding in a new ballstud provision and windowing for the fork to are all that would be required for you to have one that will work with the 168 wheel / mech. linkage / unangled fork.
Quick Reply: Bellhousing ls3-t5wc what works?
