Drop tranny help?
Drop tranny help?
I I lifted my car today, and came to what I may think to be an issue or not. On the instructions from install university and what most people say I need to take the ORY off but as you can see in the pics my pipes are welded. judging from the pics is it in the way of dropping the tranny heard of some people lot needed to take the exhaust off.
Yeah I was reading and they said you run into problems taking it off if you have the stock manifold and y pipes and now that I really look at it, it will clear gonna be a tight fit but It should not be that big of a deal! thanks for the input guys.. gonna tackle the tranny tomorrow and pointers you guys can help me out with? like how did you guys remove the bearing inside the clutch? read that the tool that takes it out dont fit some people break it out.??
Ok so I dropped it and installed clutch. What tranny fluid you guys recommend? Also where do I install the speed bleeder? And how do I use it ? It didn't come with instructions.
subscribing to thread..good luck
