Tick Slave Cylinder Shims Help
Hey guys as per the tick instructions my measurements came out to (A) 62.87mm (B) 49.82mm as you can see measurement (B) is more than 1/8 as per tick.
With both measurements I came out with a diffrence of 13.05=.514. I got all three shims from Tick but I was wondering if anyone here has ever used two shims or even all three to get within the measurements indicated in the instructions? Can anyone tell me what I need to do? I'm installing a Mantic Twin disk clutch and don't want to mess this up.
Also it should mentioned that im using a QuickTime Bell Housing with its engine plate.
Tick Slave Cylinder Shim Instructions:
https://ls1tech.com/forums/manual-tr...need-shim.html
With both measurements I came out with an air gap of 13.05=.514. I got all three shims from Tick but I was wondering if anyone here has ever used two shims or even all three to get within the measurements indicated in the instructions? Can anyone tell me what I need to do? I'm installing a Mantic Twin disk clutch and don't want to mess this up.
