LT1 to LS1 T56 strength and cost questions
I need a T56 with an LS input shaft for a car I'm putting together. I've found LT T56 transmissions for sale, but not a ton of LS T56s. So, two questions:
1) Is the LS T56 version any stronger than an LT T56 version with the LS input shaft?
2) What's the cost to have someone change the input shafts (or is it pretty easy to do)?
Thanks!
Thanks!
They are basically the same strength.
You need an LS1 input shaft, front bearing plate, and bellhousing.
$600 in parts
Unless you got the LT1 trans for a smokin price... just buy an LS1 transmission from the beginning.
Avoid the '93 version as you can't swap in the LS1 style input shaft due to different gearing.
$600 in parts
$600 in parts
$600 in parts
LS1 LT to LS
$600 in parts
$600 in parts
Also I am a good parts scrounger and have not seen an LS T56 for under $2K, or I would have bought one by now, found two LT's for $600. Worth changing over?
LT to LS T56
Are these LS t56 take outs or inspected or partially refurbished? I purchased a LT T56, however for the $ am I best off doing the LS change over or just buying a take out with engine for all the other required items.
