need help with clutch choices
Which Clutch is pretty decent, ls7 setup, spec, ram, or centerforce. I'm kinda in a budget.
My setup is 243 heads tickperformance stage 2 Cam, ls6 man and TB, long tubes full Exhaust, and spray when needed 100 Max and it a.daily.driver so I'm not worry about clutch pedal comfort
No that's the weight of just the flywheel, we have an 18lb option if you want a lighter flywheel. The heavier flywheel will help ease driving/minimize slippage with the more aggressive ceramic friction material that is required for the power you want to make, I also wouldn't recommend combining it with an aluminum flywheel as the heat that it generates can warp the steel insert. You can look up youtube videos of cast flywheels exploding if enough heat is introduced and wouldn't recommend risking that combo unless running a Quicktime bellhousing to save your feet.
