flywheel ??
Old 02-07-2014, 08:27 AM
camarozz383's Avatar
Default flywheel ??
Anyone ever use XDR flywheels? sounds cheap! so figured this would be the best place to ask, thanks
http://www.ebay.ca/itm/XTR-HD-FLYWHE...5fcb13&vxp=mtr
Old 02-07-2014, 11:48 AM
SNLPerformance's Avatar
That appears to be a factory flywheel...
Old 02-07-2014, 07:22 PM
so would it be good or bad? I have a 2008 5.3 truck engine and I need a flywheel and clutch set up to work with a t-56 manual trans, car is 3400 lbs and i'm hoping to make 450hp, can you tell me what I need, part numbers? thank you
Old 02-08-2014, 11:13 AM
I'd recommend one of our Level 1 packages with a 28lb billet steel flywheel Feel free to call me with any questions, Chris 817-750-2000
Quick Reply: flywheel ??
