Monster clutch
Old 02-15-2014, 07:42 AM
spydog's Avatar
Default Monster clutch
i have ben looking for a clutch and have ben looking at the monster stage 1 and stage 2 but i cant deside what is better for me i have a 1999 trans am stock except for the volant cold air intake some exhaust work ram air hood and a strut tower brace other than that the car is stock i dont race ar the track but i do get on it every know and than that is everyones thoughts on my setup?
Old 02-15-2014, 08:45 AM
Silver98Formula79's Avatar
I just installed the Monster level 2 clutch with an 18lb flywheel. I have about 400 miles on it. It drives real close to the LS6 clutch I had. I don't have any chatter.
I got the level 2 so I have the ability to add more power (heads/cam) later and not worry about the clutch. If you can swing it, the Tick Master Cylinder is awesome and the speedbleeder makes bleeding easy.
Old 02-15-2014, 09:21 AM
SNLPerformance's Avatar
You'd be fine with the 1, but as mentioned above I'd go with the level 2 and 18lb flywheel as there is no downside in driveability. The Tick is nice unit if looking for the fastest shifts possible, keep in mind it will increase the peddle effort if that is a concern. We always install a remote bleeder when installing a clutch here to ease initial and future bleeding required with the slave being in the bellhousing, so I always recommend one. Don't hesitate if you have any questions, Chris 817-750-2000
Old 02-15-2014, 09:32 AM
spydog's Avatar
will the monster stage 1 or stage 2 come with a Speedbleeder?
Old 02-15-2014, 09:33 AM
spydog's Avatar
also are the monster stage 1 and 2 a direct bolt in or?
Old 02-15-2014, 08:03 PM
No they don't come with a speedbleeder its extra, and they are a direct "bolt-on".
Old 02-15-2014, 08:13 PM
Zlow28's Avatar
stage 2 with lightweight flywheel here. Drives great for a DD.
Old 02-15-2014, 08:14 PM
bigken's Avatar
I have a stage 2 monster, I have 4 or 5 thousand miles on it now and I am very happy with it. I can shift the car all day at my 6,300 rpm shift point and not get a spongy pedal at all it's great! I am going to put the same clutch in my wife's WS6 after the cam install.
I don't think you can go wrong with either and it's not much more to have the level 2.
Just my .02
Old 02-15-2014, 08:52 PM
spydog's Avatar
Thanks for all the good input i think i have one last question is there a physical difference between 1and 2? From all the good input i am leaning towards the stage 2
Old 02-15-2014, 09:23 PM
I think the difference is the composites of the clutch disks. The pressure plate is the same all the way up to level 4 kits from what I have read.
Old 02-17-2014, 03:49 PM
That is correct
Old 02-20-2014, 02:51 PM
bhwunder's Avatar
I'd go with the stage 2 if I were you, I just installed one on mine two weekends ago and there isn't really any drawbacks going with the stage 2 instead of 1 besides price, but I got mine 20% off Also from what I've been told monster is thinking of going away with the stage 1 since it isn't a very big seller?
Old 02-20-2014, 06:34 PM
TheBlueKnight's Avatar
It's a pretty straight forward install. You can skip through my "how to" video to get a sense of what is involved. I got a stage 1 as I would never do anything more than bolt ons and very rarely hit the track. I also wanted an organic clutch disc material vs the stage 2's kevlar disc.
Old 02-20-2014, 10:21 PM
bhwunder's Avatar
[QUOTE=TheBlueKnight;18034899]It's a pretty straight forward install. You can skip through my "how to" video to get a sense of what is involved. I got a stage 1 as I would never do anything more than bolt ons and very rarely hit the track. I also wanted an organic clutch disc material vs the stage 2's kevlar disc.
Hey thanks for posting the video it definitely helped when I installed mine
Old 02-24-2014, 09:50 PM
wavebyby's Avatar
How to Install Clutch 98-02 LS1 F-Body Part 1 of 2 - YouTube
great video man !!!, Ive watched that video about 100 times before i did mine which I took the trans out today ( first time ever doing it ) but cant get the top three bolts on the bell housing what did u use to remove them ?
Old 02-24-2014, 10:39 PM
Lots of extensions. I think a few of the top bolts I did from inside the car right through where the shifter comes through the floor.
Old 02-25-2014, 10:29 AM
wavebyby's Avatar
yea i did that for the tranny , didnt think about that for the bell housing ill try that tonight thanks
Old 02-25-2014, 11:29 AM
Gah, sorry, didn't read it was the bellousing for some reason. I had to use a couple extensions and swivels. I pretty sure I had to use two swivels. Those things were a pain. I'm suprised one of my swivels didn't snap breaking those bolts loose.
Quick Reply: Monster clutch
