Hot spots on used flywheel and pressure plate
Old 02-15-2014, 06:42 PM
high impact's Avatar
Default Hot spots on used flywheel and pressure plate
Ok, I have an LS6 clutch, pressure plate and flywheel. These parts have under 1,000 miles and 20 track passes on them. I removed them when I started to over power the clutch after some additional mods.
The plate and flywheel have three hot spots on them. How can you tell if they are no good? I thought hot spots were normal but some guys are telling me that the hot spots mean it's junk. I think the clutch would be fine to use for a stock or bolt-on car.
Any thoughts?
Old 02-15-2014, 11:39 PM
jmd
jmd's Avatar
It's theoretically possible that you could re-surface the PP & FW, inspect the disc and re-break it in. Have a clutch re-builder take a look at it instead of "some guys" who are scared of any heat mark they see.
Old 02-17-2014, 03:52 PM
SNLPerformance's Avatar
Pics would help with diagnosis, definition of "hotspots" can vary...
Old 02-18-2014, 08:19 AM
Exidous's Avatar
Aye,
Did it get just hot enough to cause discoloration or hot enough to soften up the metal and make the hot areas no longer flat? The later needs a resurface at a minimum. The former you can get away with. If you can "feel" the hot spot it probably need to ne surfaced.
PS Steve at SNL is awesome. Just sayin.
Quick Reply: Hot spots on used flywheel and pressure plate
