T56 issues!!!
Old 03-11-2014, 07:10 PM
In-Zane Moderator
ZONES89RS's Avatar
Default T56 issues!!!
Put my 2000 t56 in my 92 s10 with a 2009 4.8. I annoy get it to be able to go into gear running and with the clutch in the floor in 1st the truck jumps when I hit the key.
I heard the 07 up 4.8 can have a longer crank but that would make clutch engagement a issue not he ther way around.
Any suggestions? It bleeds fine but I'm going to try some more.
Old 03-11-2014, 09:43 PM
jmd
jmd's Avatar
https://ls1tech.com/forums/manual-tr...d-threads.html
Shim.
Old 03-12-2014, 02:17 PM
In-Zane Moderator
ZONES89RS's Avatar
That's a last resort. Looks like I need to take the master out, flip it upside down and bleed it so the air comes out of it. Makes sense.
Old 03-12-2014, 03:29 PM
jmd
jmd's Avatar
Search jmd method.
Your method is pointless.
If my method doesn't give results, you're shimming.
Old 03-12-2014, 10:12 PM
In-Zane Moderator
ZONES89RS's Avatar
My method is not pointless since it is a method from a fellow s10 t56 swapper.
It worked so bad *** I will not be able to sleep tonight. Going to get exhaust after work and now the day will drag ***.
Thanks for attempting to help though.
Old 03-12-2014, 10:26 PM
jmd
jmd's Avatar
Thumbs up
Originally Posted by ZONES89RS
It bleeds fine
lol
My pleasure.
Quick Reply: T56 issues!!!
