LS1 Clutch with LS3/T56 Swap
Old 03-20-2014, 10:48 AM
BushyTea's Avatar
Default LS1 Clutch with LS3/T56 Swap
I am working on a LS3/T56 swap and I have a quick question about the clutch setup. I was going to go with the LS7 setup but I think I will go with a different clutch setup now.
My questions is will an LS1 style clutch work with the LS3 / T56 setup? I have the LS1 pilot bearing and slave already.
Thanks in advance
Old 03-20-2014, 05:35 PM
SNLPerformance's Avatar
I can't speak for other clutch manufacturers, but ours will. Don't hesitate if you have any questions about one of our products, Chris 817-750-2000
Old 03-26-2014, 06:21 PM
manzo81maro's Avatar
Yes any LS1 style clutch should work...LS7 is a good clutch for the money, but an aftermarket setup will be lighter and take more abuse...
+1 for Monster clutches! I love mine
Old 03-27-2014, 01:13 PM
SPEC-01's Avatar
I am not sure what flywheel you are planning to use but it is worth noting that an LS1 type clutch will need to be used with the proper flywheel. The stock LS3 flywheel has a recess that requires the use of an OE/or similar SAC-type plate. You can utilize our SC57S or SC57A flywheel and one of the SC66 clutch kits, as a complete conversion package, if you like. Let me know if you have questions and I will be happy to assist you. Thanks!!
Quick Reply: LS1 Clutch with LS3/T56 Swap
