Low mile Monster clutch/flywheel has hotspots-what happened?
Old 03-22-2014, 05:28 PM
BlueBird346's Avatar
Default Low mile Monster clutch/flywheel has hotspots-what happened?
I'll start by stating that I'm not saying anything negative about monster or their products. This clutch has been great for the 50 miles I've driven it.
I've been working on my build this weekend, got the engine and trans out today. Was taking the clutch(50 miles on it max)to find it has hot spots on both the pressure plate and flywheel. The flywheel is worse than the pressure plate.
The disc has a burnt/dark colored ring around the center, on both sides, again it's worse on the flywheel side.
So what could have caused this? This wasn't my first clutch install and I've never had a problem before, although I am human and could have done something wrong this time.
What should I do to fix this. New disc and resurface the flywheel and pressure plate? Input from Monster or other vendors would be great. Thanks in advance.
Old 03-22-2014, 06:04 PM
chrysler kid's Avatar
They need to cycle through the heat range to seat properly. You're most likely seeing the abrasion points on the surface which is part of the break in where the clutch mates to the flywheel and pressure plate.
I could be wrong but I'm sure SNL with will chime in
Old 03-22-2014, 06:50 PM
So you think it's normal? I hope so, I'm running out of money for this project lol. I'll post pics tonight.
Old 03-23-2014, 05:40 AM
stevieturbo's Avatar
At 50 miles it should still look like brand new.
If there are hot spots it has seen excessive slippage.
Old 03-23-2014, 10:34 AM
Yea I really don't think this is right. All the spots are on one half of the flywheel.
I never noticed it slipping at all. Everything seemed fine until now.
Old 03-23-2014, 10:49 AM
1BAD02WS6's Avatar
If all the spots are on 1 half of the flywheel, you might have torqued it down incorrectly
Old 03-23-2014, 11:13 AM
Old 03-23-2014, 11:17 AM
Torqueing is the first thing that came to mind honestly, but I just don't see how. I torqued it to spec. Followed the instructions that came with it.
Old 03-23-2014, 11:27 AM
oldmano2z's Avatar
could grease from the pilot bearing be the culprit? wouldn't hot spots have more colors and heat expansion marks around the circumference? just asking I would like to know myself. strange both the flywheel and preasure plate. sorry I can't help.
Old 03-23-2014, 12:11 PM
Are all the friction surfaces actually flat ?
Seems really weird that the hot spots almost seen to align with each other on the cover and flywheel ?
I'd maybe have said there was driver error somewhere with lots of slippage.
But IMO there is something very wrong with that clutch. Most of the flywheel, cover and friction disc havent even been making contact, with all load on those high spots.
Old 03-23-2014, 06:49 PM
They seem to be flat as far as I can tell.
Old 03-24-2014, 09:59 AM
BALLSS's Avatar
FWIW I pulled a clutch (twin disc) to fix a RMS leak after 500 miles. same thing, 1/2 of the PP & FW had hot spots. contacted clutch company and they said send it back (warranty). turned out the FW was .004 off from being flat.
They resurfaced FW and replaced discs & floater & PP. All good now.
I initially noticed a very slight vibe when I would just touch the clutch pedal but it immediately went away when I pushed in pedal. Turns out...the FW was not exactly flat
Monster has a good reputation on product and service, I would contact them
Old 03-24-2014, 10:14 AM
cajundragger's Avatar
go to Harbor freight and buy the $30 mag base dial indicator and set it up and spin the motor over.
seems like that would tell you what you're looking for..
Old 03-24-2014, 10:30 AM
Damn it, it did have a slight vibration. Exactly like you described. It was so slight that I didn't think anything about it. Until you mentioned it.
I don't have the instruments to measure it that precisely. Guess I need to find out if Monster has a warranty.
Old 03-24-2014, 11:12 AM
SNLPerformance's Avatar
Typically wear on one side is from improper torque or bolts backing out. We do have a one year warranty from date of purchase against manufacture defect, so feel free to call us to go over things.
Old 03-24-2014, 12:24 PM
Just talked to Monster. Chances are, it was improper torquing. Not sure how I managed to do that but I guess we all make mistakes lol He offered to check it for flatness at no charge and said that the clutch is good to go as long as it's flat.
Great customer service from Monster.
Old 03-24-2014, 02:49 PM
Mikey 97Z M6's Avatar
While it's all still relatively easy to get to, I would pull the flywheel off and check for cleanliness between the flywheel and crank mounting surface. A small piece of debris lodged in there could easily disturb the run-out of the flywheel.
Cleanliness is godliness when it comes to clutch/flywheel mating surfaces, as well as the trans to bell, bell to block etc...
Mike
Old 03-24-2014, 03:07 PM
Thanks for the tip. It's coming off anyways so I'll make sure everything is clean.
Quick Reply: Low mile Monster clutch/flywheel has hotspots-what happened?
