Shifting problems!!!
Old 03-23-2014, 08:23 PM
dustind6327's Avatar
Default Shifting problems!!!
Having a problems from shifting 3-4 unless I grandma shift ........1-2-3 does good but 3-4 won't go in hits limiter scared this **** outta me anyone have this problem?? I have spec2+ in it now
Old 03-24-2014, 05:41 AM
Exidous's Avatar
What happens if you go from 5th to 4th? Your blocker ring might be toast on 4th.
Old 03-24-2014, 10:11 AM
Everything goes fine I'm was thinking mb the master cyclinder since it high rpms,
Old 03-24-2014, 02:10 PM
SNLPerformance's Avatar
Is this after going through the other gears? How much power are you making? The master would cause the problems in all gears as it's not selective, have you confirmed the clutch is fully disengaging? If you think it's the trans, you can drain the fluid and refill if it hasn't been done in a while to see if that helps.
Old 03-24-2014, 02:27 PM
It's just 3-4 my buddy in his trans is doing the same problem I'm making 420 to the wheels I dont know what the deal is clutch is new feels good just 3-4 shifts
Old 03-25-2014, 03:49 PM
!!!FAST!!!'s Avatar
Have you done any trans work? If so, have you changed the 3/4 shift fork? Weak link in T-56.
Old 03-26-2014, 09:10 AM
Tolley's94z28's Avatar
Yep, solved all my 3/4 problems!
Old 03-26-2014, 12:17 PM
I haven't and how do u do this??
Old 03-26-2014, 12:27 PM
Also what do I need for this I'm know absoltly nothing about transmissions
Rob WS6's Avatar
The trans needs to be torn down to replace the fork. The upgraded fork is steel, where the stock one is aluminum. Also should check the blocker rings and the keys while youre in there.
Old 03-26-2014, 12:56 PM
Good deal thanks I just found a guy to do it local if I bring it to him he will do everything for 600$ is that reasonable?
Old 03-27-2014, 12:49 PM
SPEC-01's Avatar
Rob has it right, this has to be happening as a result of an internal issue. That would affect this specific shift, allowing all others to work properly.
Old 03-28-2014, 03:07 AM
Exidous's Avatar
$600 is resonable for a out of the car trans rebuild for labor. I did it all myself because there was no one in the area I could afford or trust (Hawaii). About $100 in special tools and you're gtg. Was a fun project.
Quick Reply: Shifting problems!!!
