my speed bleeder and MC lines are touching my headers
I just installed a tick master cylinder and speed bleeder and now the lines are touching the headers, has anyone had this problem ? what should i do to fix it ? I cant seem to move them and have them stay , there's a heat shield below which the lines are behind thats not the problem its up top there the line comes out of the master and sit on that shelf right under the steering knuckle ill try and take pics and post them up . the speed bleeder already got burnt up its not leaking or anything but probably close to it
Just take your time and run it and even use one of those black ties, or what ever they are called. I haven't even put my shield back on cause I made damn sure both of those lines were out of the way. My bleeder runs under my brake booster and I attached a black tie to a line to keep it off. You just have to take the time and it will work out. I did the same with the MC. I kept crawling under the car and getting back up making sure nothing came close.
