Mcleod RST and Monster twin disc users come in please
Hi guys the recent cam install is forcing me to look into a new clutch (funny how that works) anyway I want to get it as light as possible but yet still remain reasonable in price. I like the mcleod rst/rxt and it comes in around 37 lbs with a lightweight flywheel and has a much smaller MOI than a full size clutch while not breaking the bank too much over a traditional setup.
My question is what do you all think of your clutches. I hear a lot of buzz about floater rattle. How bad is it? This is my DD which is another reason for a twin disk being that it has a low pedal pressure for traffic. But I dont want it being really annoying when using light throttle cruising at 1500 rpm or so in moderate traffic or through neighborhoods. I can deal with some noise when the pedal is pushed in as I dont usually hold it in often and I suppose i could use some sound deadening in the trans tunnel but I'd rather not lol. Let me know what you all think
Dan-
Dan-
call monster they have multiple badass twin disk options for you. cant beat their customer service
imo if its a cam only car there is no reason for a twin disk monster level 2 would be a great dd clutch
I went with the RST twin disk in my car (which is primarily built for street driving and road courses) and I love it.
As far as driveability, I don't have any chatter or rattle. Engagement with a lopey cam takes a little time to learn and you will get a little surge at low RPM parking lot speeds (15 mph). This is predictable and easily manageable.
As for the benefits -- I went from the heavy LS7 clutch to the RST twin with a lightweight flywheel. The sluggishness around town is gone. The car revs very quickly and it's a dream at the track (road courses).
Thanks man thats actually the exact setup im after. I want the rst with a 15lb chromoly fly or aluminum if i find one for a decent price. Some people experience floater rattle but i guess its just luck of the draw lol. does the car seem faster/ more responsive from a roll and what flywheel do you have
YES, I was pleasantly surprised with how much more responsive the car feels. Probably a shade slower from a dig (because it's tougher to nail a perfect launch), however it feels a good bit faster from a roll.
Man I just posted my thoughts on my Monster twin here - https://ls1tech.com/forums/manual-tr...installed.html
I would definitely give them a call. I think you would be very pleased with the clutch I have based off your comments. And I believe they are priced better than the comparable Mcleod.
Some info on the Monster and some other good info also.
http://www.camaro5.com/forums/showthread.php?t=327254
http://www.ls1gto.com/forums/showthread.php?t=619538
https://ls1tech.com/forums/manual-tr...6#post18059424
The LT1-S with it's lightweight flywheel that removes all the mass from the extremity is going to have the lowest MOI if that is what you're wanting for your daily driver. It also will have the longest life out of any twin disc as it's the only one with a pressure plate that can compensate for the additional wear of a 2nd disc.
Thanks for all the replies guys. I really dont want another self adjusting PP even though it is a new design it just left a bad taste in my mouth so not looking to go that route. As it stands now I'm looking towards the mcleod with a chromoly fly.
Also been talking with monster about the possibility of their level 1 billet twin. Does anyone here have one with a lightweight flywheel if so how does it drive? Its supposed to weigh 34lbs or 44 with the normal flywheel I'm curious on either setup
I've got a 30 lb assembly and like it very much. It's challenging in stop n go but revs very nice and pulls great on the highway. I have the Zoom d2. If I was to replace mine today, I'd go ACT twin. I blew up two McLeod street twins in several hundred miles.
Good luck.
Good luck.
ya that seems to be where i'm leaning for the price its hard to beat, its got great reviews for driveability and the weight is around 36-38lbs with a small MOI because of its smaller size.
now the question is do i pickup a used fidanza and get a new insert or go with the chromoly flywheel?
also are you all balancing the whole setup before it goes in the car when you use a non mcleod flywheel
Luk (maker of the lt1 clutch) have vastly improved the self adjusting PP. Should be a non-issue now. But the RST does have a REALLY soft pedal being it's a PP from a Honda I think. There are a ton of folks out there that are happy with either company so you really cannot go wrong. Just stick to the organic disk for whomever you choose.
If you want a really fast revving motor you really are not going to get it with the LT1 clutch as the PP and floater are quite thick and heavy. BUT that's a good thing. Less likely to warp and can take more heat.
I know this has been beaten to death but do u all think aluminum or a chromoly flywheel?
7200rpm shifts after launching off the limiter with slicks, I'd say so...
cough V6 Camaro cough
Chromoly over aluminum as a lighter flywheel is going to need to be slipped more with a heavy car and stock gears to get going and the steel insert in the aluminum can warp with the heat, so that is why I would not recommend it from experience before I worked for a clutch company. If you have a cam any bucking will be more pronounced with a lighter flywheel that absorbs less harmonics as well. Hope that helps, Chris
This is my main thing if I'm dropping some coin on a nice setup I want it to rev quick and be good for rolls. The monster does have a light flywheel option to remove some weight from the outside but nonetheless it still is a bigger heavier clutch so it should inevitably have more inertia futher from center.
Hmmm. I just picked up a car with the McLeod street twin. The petal is heavier than stock, and the engagement it set all the way down. Shifting it pretty bad as it takes a second or two to shift into the next gear at WOT. I wonder if a tick MS would solve the shifting issue?
clutch could also be worn or not installed right (shim stack height)
