hydraulic tob AN fitting
Does anyone know what size clutch line fitting I should have in my hydraulic throwout bearing? I run a Spec clutch but I think they use quartermaster 721 throwout bearings.
It was leaking so I disconnected the lines, and it looks like its supposed to have an AN-3 threaded into the TOB... also not sure if it is O-Ring Boss or not. Can anyone tell by these pictures if it's supposed to have an o-ring on the AN fitting or not? Is there any harm if I put an o-ring on there and it's not supposed to have it?
I would just try it out and see what happens but it's a real PITA without dropping the trans.
Thanks!!
Thanks!!
