hard to get into any gears help! 00 ls1 t56
Ok so replaced my clutch with a tdp diamond clutch stage 2 slave also replaced worked great for break in period I did a couple digs after break in and it started getting hard to go in 1st 3rd and reverse so I figured clutch master was out the fluid was black and dirty as **** replaced that with a stocker it got better for a couple days then I let it Sit for a day went to drive to work got a couple blocks from my house pedal Went to the floor kept driving it it Got a bit better got home later parked it a few days went to get in it and its super hard to get in any gear while running if it's off it'll go into gears good except reverse what do you guys think the problem is any help is greatly appreciated
I replaced the clutch with a tdp diamond stage 2 clutch complete kit came with clutch disk pressure plate throw out bearing and new slave. Car ran great for awhile then what I explained above happened
Third was grinding a little but now it won't go into any gear and when I try to go in gear it starts creeping forward as soon as I start putting it into gear won't go in but it'll start creeping
My buddy helped me with the install we did everything by the book and he's done quite a few 4th gen clutch swaps but that doesn't mean we didn't screw something up. You think the slave could of went bad running that old Shitty fluid through it?
Yeah starting to save for a tick now. Are you talking about the drill mod or actually modding the clutch master?
drill mod removes the check valve thingy in the line lets the pressure release quicker. which does away with sticking pedal . to make it adjustable you have to disassemble and and cut internal stop and cut the rod and thread it on both ends where it is cut and put the jam nuts and sleeve on them you can adjust it. should fix your problem
Why was there old dirty fluid in it if you just replaced the slave and clutch? Did you not bleed the system after the clutch/slave replacement? If that's the case I'd try bleeding the **** out of the system, and when you think you're done run another bottle through it then get back to us.
