Built t56 or 6060 for 02 TA
a t56 magnum/6060 will be stronger no doubt if you got the funds if thats an issue do a t56 put a pump on either one and should work well for you. Rpm transmissions is no doubt the best they built mine and its been holding up to 800+ and looked perfect when torn down after this season. give jeremy a call he can get you set up
A T56 Magnum will shift better than any upgraded pre 2008 T56. Plus it already has a 31 spline output shaft, everything inside is made of a better material, the case is a better casting, provisions for a cooler.... built in sprayer.
I've run both.... and love my new Magnum. worth the $
