tick master help
tick master help
So I have a 2000 ss I just put a adjustable tick master cylinder and I don't get how to adjust it I turn the barrel nut to make it longer then I hear space hit the pressure plate shorten it up and feels like stick and still wants to stick at high rpms please help. Thanks for any help
can't understand that 100%, but you should adjust it so that the clutch pedal is just underneath or level with the brake pedal, flush system with DOT 4 and make sure all air is bled out..also pedal should be firm all the way...does the car still have the stock clutch?
