TR6060 VSS gear tooth count /vss pulse output
I am working on retrofitting a TR6060 from a 2010 camaro into a 67 F body. I am trying to calibrate a cable-x to work with the factory gauges but having troubles with accurate readings.
Does the TR6060 have the same 17 pulse per revolution output for the vss as the T56 or is it different?
Sorry if this has been asked before but I am having trouble finding anything about it.
