99 camaro ss slp clutch info needed
hey guys my buddy picked up a 99 ss slp package and wants to do the clutch, says he has trouble getting into 1st and reverse at times. I told him to first try to flush and change fluid in slave cylinder but he seems set on a new clutch. I told him to go with a ls7 clutch but seems like to do that you need to swap the flywheel. If he went with a ls6 clutch would he need to swap the flywheel or will it mount on the ls1 flywheel? thanks again
How much power does he plan on making? Our Level 1 is better than a LS7 unit if he's going to spend the money on a new flywheel it might as well be a billet steel and a pressure plate that can hold more power. Don't hesitate if you'd like a quote or have any questions. Chris, 817-750-2000
