Need straight answer on where to get Slave cylinder
1 Post
I hear 10 people giving 10 different where and what to buy stories. I have a plain casting(black)green disconnect(if that matters) now. It's new but, the Made in China label isn't giving me a warm and fuzzy feeling right about now. Pulling my tranny in a month from now for another slave won't be good for my health aside from the new words I come up with while looking at a puddle on the driveway. Thanks in advance.
Save the manuals!
The AC Delco slave is the one you have to worry about. Just don't get that one and you are on your way to being fine. I recall somewhere that they are made in Mexico. I am one of many victims of the AC Delco slave and have been fine on the GM model. (FYI - For this part GM does not equal AC Delco. I expect this may be part of your confusion?)
I got mine from NAPA for like $60. I can't remember the part number right off, but I have it somewhere. I could get you a pic of it if you needed one. It is the silver casting one with AP stamped on it. From everything I read the AP casting is what you want which is why I went with it. I haven't completed my swap so don't have any more info than this.
The silver ones are problematic, I believe their inner seal design is what causes most of clutch fluid contamination and pedal issues.
The silver one is not a true delco piece, it was out sourced long ago which is why autozone and oreilleys pieces were identical and had identical stampings. The black ones I'm sure are Chinese too
I have not used the black one yet but it appears to have tighter tolerances compared side by side with the silver one.
