Flywheel for LS7 clutch??? Yes - I searched...
Old 07-03-2014, 08:42 PM
74u
74u's Avatar
Default Flywheel for LS7 clutch??? Yes - I searched...
My car is a 99ss with recently built & installed 416 stroker. I have a serious clutch chatter problem so I decided to throw a new LS7 clutch in it. Being it's a street car that will not see sticky tires I want the smooth engagement and light pedal these clutches are known for.
Anyways, without doing any research I bought the clutch today and dropped the trans only to find my flywheel may not be compatible. Looks like I need a flywheel with raised mounting points for the pressure plate as opposed to my flywheel which is completely flat across the PP mounting & engagement surface.
Now I've started doing some research and keep finding the part number for a flywheel members of this site have used with the LS7 clutch (12571611) but every picture I can find of it appear to be a flat flywheel like the one I already have.
Can anybody point me in the right direction? What part number flywheel should I be looking for...or am I mistaken and my "flat" flywheel will somehow work?
74u is offline
Old 07-05-2014, 09:09 AM
The Scammer Hammer
dr_whigham's Avatar
You have to crush a beer can and put it BEHIND the flywheel.
No need for shims either. The pull tabs work great for that behind the slave.
dr_whigham is offline
Old 07-06-2014, 08:55 PM
74u
74u's Avatar
Wow!!! What a unhelpful d!ck...I hope the rest of your 4300 posts are better.
I was able to figure it out but thanks anyways
74u is offline
Old 07-06-2014, 10:01 PM
Project GatTagO's Avatar
Received 1,389 Likes on 878 Posts
LS7 clutch needs a LS2/LS7 style stepped flywheel.
Like this:
Andrew
Project GatTagO is offline
Old 07-07-2014, 08:28 AM
The Scammer Hammer
dr_whigham's Avatar
Originally Posted by 74u
Wow!!! What a unhelpful d!ck...I hope the rest of your 4300 posts are better. I was able to figure it out but thanks anyways
My point was 10 seconds on google or getting on the horn with a vendor would have solved your question...
Quick Reply: Flywheel for LS7 clutch??? Yes - I searched...
