T56...how much power?!
Old 07-07-2014, 01:44 AM
"I MAID THEESE"
Mavn's Avatar
Default T56...how much power?!
About to do a t56 swap since my 60 went out ... If I get a nice clutch, how much power should it hold? I'm about to be cam/heads/intake on a 100 shot.
Thanks!
Old 07-07-2014, 07:44 AM
fleetmgr's Avatar
I believe they are rated at 500 ft. lbs.
Blackpanther99's Avatar
There is really no specific answer in how much they hold, sometimes they go out on stock cars, while other push them pretty far. Its all in the shifting. I remember a time
Back someone here posting about them pushing the stock clutch over 400RWHP.
Old 07-07-2014, 07:45 AM
And this ^ is the usual rating.
Old 07-07-2014, 08:26 AM
redbird555's Avatar
I have 243's and an f13 cam in mine and its stock with carbon blockers and iron 3-4 fork. Never an issue same with my buddies only he has a built lq9. They can take a lot of abuse as long as your not an idiot, flat foot shifting and missing gears will eventually kill it. I have pushed my stock clutch over 400whp now and its doesnt like it lol new rts is going in soon
Old 07-07-2014, 09:38 AM
HCI2000SS's Avatar
Heads cam and a 100 shot here, and no issues with my T56
Old 07-07-2014, 05:14 PM
SS_TOR's Avatar
sorry this is probably a dumb question but can you elaborate on what you mean it's all in the shifting?
Old 07-07-2014, 05:40 PM
Tally TransAm's Avatar
mine died with about 680 rwftlbs and a whole lotta traction
Old 07-07-2014, 07:09 PM
murphinator's Avatar
it will take heads/cam type power well if you don't speed shift or power shift it , the stock 10 bolt behind a cam/heads/6 speed combo likely wont last long if you hook it up though...
Old 07-07-2014, 07:56 PM
BALLSS's Avatar
meaning not to speed shift especially when not lifting the gas.
Can they be shifted aggressively behind a motor making power, yes.
Having a good clutch system with perfect working hydraulics is a critical component also that if F'ed up will wear any transmission .
Old 07-13-2014, 05:46 AM
stevieturbo's Avatar
Thanks!
Can you enlighten us as to what a "nice" clutch is ?
T56's can and do hold plenty of power.
Old 07-14-2014, 10:39 AM
Agreed^ a good quality clutch will make that T-56 last longer.
Old 07-15-2014, 12:28 PM
necrocannibal's Avatar
I had a stock T-56 with a 408 stroker and 200 shot on it. Made over 750 ft lbs at the wheels and it lived ok.
Old 07-16-2014, 04:28 AM
romfireman86's Avatar
Which T56 is the best bang for the buck?
Old 07-16-2014, 09:47 AM
2nd Gen Fl 'bird's Avatar
4L80 FTW. Unless, you feel the need to row gears.
Quick Reply: T56...how much power?!
